I plan a trip to the mountains in Colorado in a couple of weeks. I have an 05 FLHTC with a 95 incher. How much problem am I going to have \\;with the higher altitude as far as how the bike runs?
Yep, if it's the stock CV (or any CV for that matter) you'll have no trouble. \\; Of course you know the power will be less the higher you go but that's normal and unavoidable. \\; It will run fine though.
Wellllll, MAYBE you'll have trouble. \\; Generally, CV carbs do adjust somewhat to changes in elevation, but when my bike was still bone-stock, I took my yearly trip to mile-high country and fouled the plugs big-time. \\; Since then, I haven't had a problem, and I've gone with the Sporty needle and an EV13 cam, but I always have spare plugs with me and change them if I have any inkling I might need to. \\; If you have one of those carb kits that make your bike run disastrously rich, you might have a serious lack of power in the mountains.
Yeah, we should say that *IF* your carb is jetted somewhere in the vicinity of correct then you'll be fine. \\; But if you're running fat, wet, and sloppy at sea level then it'll just get worse at 9,000 ft!
