Spark Plugs
Spark Plugs
Need some advice. Changed the exhaust and intake on my 07' Dyna. V&\\;H HS slip-on's, FuelPak and K&\\;N RK3910 High Flow Kit. The bike pops and backfires on decel. I did run the bike with the pipes and fuel pak for approx 500 miles before changeing the intake. This may have caused a rich fuel condidtion. I pulled the plugs and they have a powdery white appearance. Per the HD manual, white is acceptable (no mention of powdery). In my experience, a plug from and engine running the correct air/fule mixture should have a nice tan or carmel color. White was always a sign of being too lean or too hot. Any suggestions?
Gonna by a new set of plugs today and see if that makes a difference.
RE: Spark Plugs
I'm sure an Expert will have the real scoop but \\;I wouldn't worry about a white electrode on plugs anymore because \\;many all the gas additives out there will cause what was tradionally called a lean look. I would worry only \\;if the inner steel wall between the electrodes and threads of the plug is white. The backfiring can be caused by a leak in the intake or exhaust and since you recently did some intake work I would check that first.
RE: Spark Plugs
I am an old mechanic and am slowly getting used to white plugs. \\; I guess the new fuel burns cleaner. \\; Mine are a powdery white with a slight gray tint. \\; It is those bleached white glazed with black spots that isn't good. \\; Reading plugs just isn't what it used to be.
RE: Spark Plugs
I am experiencing a popping and occasional backfire on decelleration. I have the Vance and Hines slip on mufflers, Vance and Hines Fuel Pak and K and N RK3910 high flow kit. I will pull everything tonight and
re-install and replace the spark plugs at the same time. If I have a leak at the head pipe / muffler joint does anyone think that would cause the popping and backfire?
RE: Spark Plugs
If you dont have an exhaust leak, then the bike is lean in the zero throttle position. \\; Richening it up a bit in that range will eliminate the popping on decel.
White to a slight gray condition is pretty much normal anymore, unless as others said, you have \\; black spots as that is an indication of detonation. \\; If the whole plug, electrode, insulator is white, then again, you are a bit lean.
