s&s e carb jetting
Old 05-29-2008 | 12:00 AM
monty101's Avatar
monty101
3rd Gear
Default s&s e carb jetting
I have 14 miles on a new shovelhead build, 96 ci truett and osborn torquemonster , andrews b cam and s&s e carb. No matter what intermediate jet I put in I have to turn the adjustment screw out 2 1/2 turns to get it to idle. What could cause this. I did a pressure test on the intake and it isn't leaing and I used halimar on the fiber spacer to make sure its not leaking where I put the 2 bolts in that hold the carb to the manifold. It appears that the only way the motor will get enough gas to idle is to open up the adjuster all the way. What would cause the motor to not suck fuel at idle in enough quanitity that I don't have to turn the screw out 2 1/2 turns? I don't think its a vacuum leaks so i guess some where some place there is a restriction in the carb that's making very little gas go through that intermediate jet. The adjustment needle looked ok. It long and pointed and doesn;t appear to be broken off. Anybody got any suggestions??
Old 05-29-2008 | 12:03 AM
monty101's Avatar
monty101
3rd Gear
Default RE: s&s e carb jetting
oh yeah I've tried a 295, 310 and 320 all need the screw turned out 2 1/2 turns to idle. I', running a 74 main jet
Old 05-29-2008 | 02:55 PM
jcsportster's Avatar
jcsportster
I would call S&S and Im sure they will help. You can find their number on their web site. Or e-mail them. They are very helpful.
Old 05-29-2008 | 07:50 PM
monty101's Avatar
monty101
3rd Gear
fixed it new needle
Rusty Axle
Shovelhead
06-03-2017 09:32 PM
cajun1957a
Shovelhead
02-11-2014 10:23 PM
kd4tsc
20
02-08-2010 08:42 PM
chopmafia777
09-21-2009 10:19 AM
strantor
06-09-2009 11:26 PM
