OK To Punch Out Stock Baffles?
RE: OK To Punch Out Stock Baffles?
I just read in another section of the forum that if you are just changing the stock mufflers to SE mufflers you do not need to change the air cleaner and remap the fuel injection.
A guy at my Harley dealer said that the SE mufflers are high performance and have less resistance than the stock mufflers so you have to give it more air by installing the performance air filter and remap.
Who's right (and will you damage the engine if you just replace with SE mufflers without the other stage 1 modifications)?
By the way this forum is great.
Generally the common consensus I've seen carver is that if you just change out pipes (for the most part), you don't have to change out the rest. If you change the A/C also, then you need to rejet or remap.
Halfbuck, I punched out the baffles on my 03 Lowrider, and didn't run into any problems. But then I only had the stock pipes for about 3 months after that, then I switched to a set of HK's (and rejetted, Ness BS a/c). I didn't notice a performance loss.
I punched through the baffles on mine, I thought the SE2's were too loud and tinny sounding. The bike is rejetted, running a K&N filter in a drilled out stock airbox and SE 6200 RPM race ignition. Runs great, pulls hard and sounds good. I had an SE airfilter and teardrop cover on for awhile but it rains alot around here and after I read about blue SE filters falling apart I took it off for a look-see. It wasn't falling apart, but it was covered in mud and sand from road spray, and it looked like crap was tracking along the trough where the front breather goes in so I did the Po' Boy custom job and swiss cheesed the back of the stock box.
They sand the roads here in the winter when it gets icy plus it rains all winter long so the road spray is this nasty mix of sand and muck, I don't think open filters are a good idea if you ride in the winter here. My Dyna is set-up for the conditions I ride in and and it runs and sounds fine. You do what you want with yours.
Carver, I feel your pain. I installed SE II's on my EFI bike and was told by the dealer that NO remapping was required for just a slip on exhaust install. Seems to run fine, except some "popping" on deceleration (which sounds pretty cool to me, hopefully no engine damage is occuring). Now I am thinking about some SE 16G Double Barrel's, since SE is getting ready to d/c making exhaust. After reading all the posts on this forum, I am confused as to what to do. My dealer says I need a A/C kit, SE Race Fueler, and ECM remap. Posts on this forum I have read say a SE Race Tuner is needed...? Any help from anyone???
