Baffles
RE: Baffles
They should be a little quieter. Did you have the system remapped when you put them on.
If you did you might have to remap. If you are running the stock map you probably be ok. You will be actually increasing the back pressure.
When you put in the new baffels, change plugs. After a couple of hundred miles pull them and check the coloring.
http://www.msttn.com/dyna/plugcolor.htm
Larryc5079
06-15-2007 09:05 AM
