strange sounds
strange sounds
I have a bascially stock 98 softail w/ EVO motor.
I have a "puffin" sort of sound coming from the vicinity of the carb, sounds like leaking compression or something, you can even hear it when the engine is not running and you are cranking it with the starter. Sort of a puff-puff-puff like air pumping... I dont think its an exhaust leak. Any ideas?
Also the bike is having troubles idling without the choke.
Only thing i have changed is Bike had drag pipes on it and i put a stock exhaust setup back on.
