fuelpak settings for fishtails w/ duals on an 04 RK Custom
Old 05-07-2008 | 10:19 AM
higlet's Avatar
higlet
Default fuelpak settings for fishtails w/ duals on an 04 RK Custom
So I've got a V&H exhaust setup with the fuelpak. I've got the fishtails (standard baffles) w/ the dresser duals, hi flow intake, stage 1 ecu, no internal mods.
Unfortunately V&H does not list the fuelpak settings for this setup. Has anyone else got this setup, and know the FP code? I've emailed them for it, but they haven't had a chance to get back to me yet. All the ones that are close are way different from each other, so I don't really want to hit and miss with it.
Old 05-07-2008 | 10:37 AM
winston chopper's Avatar
winston chopper
Default RE: fuelpak settings for fishtails w/ duals on an 04 RK Custom
Hi, its capt obvious! did you call them . They have a tech line.
Old 05-07-2008 | 10:45 AM
higlet's Avatar
higlet
Thanks Captain
As Admiral No****ingKidding I will point out that the tech line is open at 8amPST
It's still not 8
Thanks for all your great help.
Old 05-07-2008 | 10:50 AM
winston chopper
Glad I can help. You would think the Vegas sign would have tipped me off.
Old 05-07-2008 | 10:55 AM
winston chopper
I like the fuel pak . Their setting runs mine alittle rich at idle but I did a higher RPM plug check by shutting it off at 60 MPH at about 2500 Rpm and the plug looked good. It beats payin $450
and dyno and install time for a sert.
Old 05-07-2008 | 01:54 PM
higlet's Avatar
higlet
Turns out for that setup it is FP-0106
Which they do not list on the application guide.
Ryder206
12-09-2018 02:45 AM
07FLSTC_Navy
07-28-2007 03:20 PM
skratch
04-03-2007 02:09 PM
TKanaley
06-11-2006 10:25 PM
Anthony8858
05-24-2006 07:04 PM
