FatCat baffel change
RE: FatCat baffel change
valkal... just a ? is the std. baffle to loud or ?? I was thinking about a black f/c but not sure of the baffles.. Phil's done some test's and the quiet baffle works a little better,, but sound IS important to me too. If you could compare your std. baffle's to a Thunderheader (too loud,for me) or a V/H pro pipe (sounds good)..
Is it too loud at higher/freeway speeds/around town?? I don't want to regret buying the wrong baffles..I guess I could buy the quiet one try it then buy your std.
off you when I don't like it.. Thanks Steve
ORIGINAL: vibr8ir
