circlip installation
Sounds like you found the way to do it without the proper tool, gauge the piston, flys through ths air and hits you in the eye and bounces off your face and into the bottom of the crank case. The next step is to try a different approch or you could go rent the proper tool.
ORIGINAL: duke76
Use, a piece of copper pipe and install the circlip in the copper pipe, then push the circlip into the pistonwith a socket on a extension, hope this makes sense, maybe some one has a picture. Todd
ORIGINAL: Doc 1
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
I have used the copper coupling and I have found that if I use a thin pair of needle nose pliers and a small screw driver that I can do it just as easily. make sure you have clean rags stuffed in the case holes. It also helps if you have an extra pair of hands holding the piston/rod still. The KB pistons have cool spiral locks that are really nice and I wish they all had them.
I never thought of the pipe thing, but it makes perfect sense. Thank you so much for the help. Now I'm convinced as to why I come to this forum for help. The money you just saved me on another specialty tool will now go to a paid membership here. Thanks again. Jay
Shawrco
Exhaust System Topics
01-23-2013 04:01 PM
Jor3lBR
General Topics/Tech Tips
07-15-2008 08:15 PM
