Gas and octane booster in the HD
RE: Gas and octane booster in the HD
If your bike is stock compression, it's only 8.5:1. Using higher octane is of no benefit whatsoever, and might actually make your bike run worse. Lower compression engines create less heat and need hotter burning gas for efficient combustion. Lower octane gas burns hotter. My 92 has never had higher than 87 octane and runs fine at 130K+ miles.
Just got a reply from Fuel Magic
Charles,[/align]Fuel Magic contains no lead, alcohol or sulfur that may void engine warranties. Fuel Magic, as stated on our website, is made of different compounds of hydrogen, oxygen and carbon.[/align][/align]Thanks for your question.[/align]Sales[/align]www.fuelmagic.net "[/align]
I usually run high compression and when running in hot areas or extreamly hot weather(kansas last year 104 degrees)I run boosters or additives and have good luck with some of them.Lucas fule additive doesnt boost octane but has given me better millage in trucks and Im going to test it this year on 8000 mile road trip.Ill post results in june we leave mid may and get back in early june 2 1/2 weeks of no head aches maybe some *** aches but no head aches.
ORIGINAL: madcritter
Toluene and Xylene dose not Lubricate upper cylinderor inhabit corrosion which I consider important and Duralt does as well as raise the octane 3 to 4 numbers . Which if I go back to using 87 % as required by the manual I'm still a head of the game. Like I said HD fuel additive has been used in my bike all along and at 39000 miles is still strong.
http://ezinearticles.com/?DurAlt-Fue...&id=479245
What wrong fuel, as I stated in my 1st post the manual calls for min of 87 % octane. So if I am going back to 87% and get any boost what the problem ? I have used MVO in a number of my vehicles but never in a bike. I would have to make sure it contained no lead first. Think I have a bottle out in the shop will checksee whats in it.
You're correct, I was wrong assumed your bike was not stock, and you know what you get when you ***-ume things...87 octane is fine as your bike is low-compression. You won't see any benefits from octane booster with your compression ratio. I'd still consider Marvel Mystery Oil as a less-expensive top end cleaner.
Well, broke down and put 3.6 gal of regular in the bike today. Used the last of my HD fuel additive. Next tank will be with a different lube additive. Did read where they used Marvel even for cleaning guns. Guess it could do double duty around this house.
