What's the best 2-1
Old 04-14-2008, 01:01 AM
wydopn231's Avatar
wydopn231
wydopn231 is offline
Default RE: question for Doc 1
as for doing fuel controller your self If your not confident enought to change the pipes Id think 10 times about the controller.Pipes are super simple to change.Some controllers are fairly simple,but they need dyno or someone very good at tuning and engine.The one that tune easy without dyno are lot my complicated to install.Or this has been my experiance.Then Im very machanical inclined and not so computer inclined.
Old 04-14-2008, 07:43 AM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
Bassani Road Rage, perfect torque curve with the heads and cams I use.
Old 04-14-2008, 04:30 PM
Firetender's Avatar
Firetender
Firetender is offline
ORIGINAL: Doc 1
Good question.....the bigger the build goes the more flow you need to expel the exhaust. For your typical 95',96', 103' with a .510 lift cam orcomparablethe Quiet baffle will work. When you start getting into the 2' intake valves and 107' with a .590 and up cam I would go with the free flowing baffle. I've seen some good builds fall on their face at 5000 rpm because of too much restriction from the quiet baffle, however using the free flowing baffle on a build that doesn't need it will suffer in the lower rpm power band where you ride all day long.
+1 to that!
Old 04-14-2008, 08:39 PM
brickie's Avatar
brickie
brickie is offline
ORIGINAL: Kingofcubes
Kingofcubes could you discribe your enginebuild as I am interested in getting more power out of mine but havn't decided which way to go yet.
Old 04-15-2008, 12:01 AM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
I really like my D&D fatcat, but do not have a radical engine.....yet..... Smiles per mile
Most likely next prgression will be ( less beers ) LOL and GRM package to build my 96 to a 107 !
Cheers,
Mark
Old 04-15-2008, 07:55 PM
gunnert's Avatar
gunnert
gunnert is offline
#1: White Brother E pipe, 2-1, with mountain motor core (discontinued, you can find one on ebay every now and then).
#2: D&D Fatcat
Nicky Pass
11-22-2011 01:36 PM
usefulshrimp
07-24-2011 11:37 AM
crewchief25
05-16-2011 09:10 PM
harley_nova
07-31-2009 08:16 PM
OMC.SGF
11-09-2007 11:00 AM
Quick Reply: What's the best 2-1
