Replacment baffles for SE slip-ons 2007-2008 model touring
Old 03-29-2008 | 10:45 AM
VTwinJaxFL's Avatar
VTwinJaxFL
Default Replacment baffles for SE slip-ons 2007-2008 model touring
Anyone experimented with changing the baffles on the 2007-2008 touring SE slip-ons? A buddy mentioned thatBig City Thunder had a replacment baffle that would give the sound a little deeper and slightly louder exhaust note. I'm not talking about their small baffle with the washer hanging down on the bolt type baffle. I call these the lollie washer, I can make some like that myself. These are suppose to be replacements for the SE baffle. I checked their website and see they have some for the older SE II mufflers, but no mention of any for the 2007-2008 mufflers, which are different.
Anyone have any advice on this topic? This is for 2007-2008 Touring Screaming Eagle Slip-on exhaust only.Not interested in any earlier version of these pipes unless it also works on these. Any brand or make of baffle is okay.
Old 03-29-2008 | 11:32 AM
bob2002's Avatar
bob2002
Default RE: Replacment baffles for SE slip-ons 2007-2008 model touring
If your talking about the two piece 4" muffler Ilike to know the answer to that too,I read on one of the forums that the stockSE baffle can be modified by bending the baffle where its cut and bent down back up so less of the exhaust flow goes thru the muffler andstraight thru instead but I haven't tried that yet.
Old 03-31-2008 | 08:22 AM
VTwinJaxFL's Avatar
VTwinJaxFL
No, these are the standard 1 piece muffler, part #80491-07, they are called Sreaming Eagle Street Performance mufflers one piece.
Old 04-04-2008 | 04:04 PM
VTwinJaxFL's Avatar
VTwinJaxFL
Anyone, I am sure someone knows the answer to this.
Old 04-04-2008 | 09:21 PM
MCSarge's Avatar
MCSarge
Check out this link it might help: www.hdforums.com/m_2902904/tm.htm
Old 04-04-2008 | 09:41 PM
skulznflames's Avatar
skulznflames
Went down the same path about 6 months ago, at that stage they hadnt made a replacement baffle for the 07 SE Mufflers (not sure if they have yet either) so I pulled my baffles out and cut them off at the squashed section, drilled some more holes in the baffles, then rewrapped them.
WOW, what a difference that made, made an immediate increase in low end torque and now sounds like a Harley should.
mikiem
06-21-2015 10:52 AM
02RiderFLHRCI
08-14-2011 03:59 PM
crazycanuck
04-18-2011 02:20 PM
DrPlastic
04-16-2009 09:42 AM
TNBagger
02-14-2008 02:22 PM
Quick Reply: Replacment baffles for SE slip-ons 2007-2008 model touring
