Anyone put an andrews 54 in a stage 1 96 yet?
Im looking for someone who has used the Andrews 54 cam in an 07/08 bagger with just the stage1 air cleaner, slip on's and SERT.
If you have used this cam as a "bolt in", please reply with your experience and dyno results if available. I know there are other cams available with different opinions, but I am specifically looking for someone who has already used this cam in the configuration I described. Thanks
RE: Anyone put an andrews 54 in a stage 1 96 yet?
Check here, it has several dyno posts of what you want. http://groups.msn.com/harleytechtalk...D_Last=1288531
Streetglide,
Thanks so much for that link. They had an 08 with just the 54H cams and I was able to see where ther power comes on with this cam, and my setup. Looks like 2500-5500 is where the torque stays up. Exactly what I'm looking for out of a bolt in cam. Nice numbers too. I'm looking to do this swap this summer.
I won't get into the details of why I disagree with nightrider, but I do. The 54 cams were specifically made for the 96's. Nightrider is a little behind the curve. Woods 6's and Andrews 54's are the best cams out there right now for stock stage 1 96 motors. I just prefer the Andrews products.
VicW.
