Anyone put an andrews 54 in a stage 1 96 yet?
Old 03-27-2008, 01:14 AM
labfreak's Avatar
labfreak
labfreak is offline
Default RE: Anyone put an andrews 54 in a stage 1 96 yet?
ORIGINAL: mtb017
Thanks for the reply. Yes, btw it is fine as a bolt in cam. Anyone with before and after numbers, I'd love to know what they are and where the Torque comes in at, compared to just a stage 1.
Not trying to be a wise azz, but you'l need hi-lift springs if'n you are puttng a 54H in a '07-08 Dyna see : http://andrews-products.com/PDF_file...ainCam0708.pdf
Old 03-27-2008, 04:13 AM
Sleeps In Trees's Avatar
Sleeps In Trees
Sleeps In Trees is offline
The '06 & up heads have beehive springs that handle the 54's .555 lift just fine.
VicW.
Old 03-27-2008, 10:29 AM
donk_316's Avatar
donk_316
donk_316 is offline
Yes the 54 is a direct bolt in cam. Your stock 96" springs are big enough.
Old 03-27-2008, 02:43 PM
mtb017's Avatar
mtb017
mtb017 is offline
lab, the catalog is wrong as far as the newer head models. Beehive springs on the 07&08's can handle these cams easily.
You're not a wiseass, Just don't believe everything you read on a website.
Old 03-27-2008, 05:22 PM
Sleeps In Trees
Just a FYI: '06 heads have the same [beehive] springs & I think some of the '05's do too.
VicW.
Old 03-27-2008, 11:10 PM
labfreak's Avatar
labfreak
labfreak is offline
ORIGINAL: mtb017
Dude, with all due resprct, this is NOT JUST A WEBSITE, it is ANDrews OWN WEB site and they are not presenting the 54H as :"botl-in" to back this up,just go to www.bifbooyzcycles.com and look at the conparator. it does NOT come up as a'bolt-in"
Do some researdh BEFORE yu ecommend stufff, man, you are wrong on this...
Old 03-28-2008, 06:13 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
I'll chime in an alert you folks to a Bob Wood 6 in a 96" we justcompleted, for a client in Ft. Ann , N.Y., that rolled 104 hpand 114 ft/lbs. Our heads, 6 cam ,Rinehart 2/1, OE t/body, high flow air filter(NOT S/E, as they do not count as a high flow unit) Good numbers for what was done. Much more available if pistons, different cam, roller rockers, larger t/body.
Old 03-28-2008, 08:15 AM
mtb017's Avatar
mtb017
mtb017 is offline
lab, no disrespect taken. I originally saw that on their site too, and did research it. It is not "necessary" to use high lift springs. Because the lift of this cam is .555, it is in the category of a "high lift" cam. Beehive springs are generally fine up to lifts of .600,actually even a bit more. It is well documented that the Andrews 54's are great boltin camsfor 07 and 08's. As I said and a few others here, the beehive springs usedon 06's through 08's are fine for the lift these cams have. I have also personally verified this through one of the top tuners on the east coast. I'm not going to put anything in my bike that's going to "f" it up, trust me. The purpose of my original post was just to find others who have used this cam in my specific application, and see if the torque comes on where it was designed to.
Old 03-28-2008, 01:50 PM
labfreak's Avatar
labfreak
labfreak is offline
OK, point taken, I'll have to re-evaluate this myself as I was about to order the 37H. sounds like you have your research done, thanks
[sm=icon_cheers.gif]
Old 03-28-2008, 03:37 PM
Sleeps In Trees
The stock springs in the '06 heads I'm running work fine w/the54N's that John Andrews gave me to test in my '02 95"er. FREE!! Many thanks to Dewey for setting me up w/this deal! You da mans homes.
VicW.
Quick Reply: Anyone put an andrews 54 in a stage 1 96 yet?
