Dented Exhaust Head Pipe- Problem???
Hi All,
I had my bike in for a set of cam upgrades. The mechanic removed my front exhaust pipe to replace the cams, etc. When he put it back on he did not adjust it right and the brake plunger was tight against the pipe causing it to drag. Without bothering to adjust the exhaust pipe, he takes it off and proceeded to bang a big dent in the bottom of it to clear the brake plunger.
Now the pipe has only about half the flow going through it even though its sort of flattened out. I'm not worried about the chrome damage because the pipes are wrapped, but I am worried it there will be any performance loss or problems with him doing this.
Anyone out there with enough knowledge or experience in tuning to give me an answer either way before I take it back in and complain to the shop manager about his mechanic? I noticed the dent when I was cleaning the bike a day later after I got it home and parked it in the garage.
Thanks for any help on this.
1 Post
RE: Dented Exhaust Head Pipe- Problem???
Sounds like you need to make them replace your pipe. I would for sure find a differentmechanic and I really question why someone would beat a dent in a pipe to make clerance for something that was working fine and had nothing to do with what you took it in for. Pertty sorry if you ask me....well you did! Good luck
Djcamis
2014-2023 Touring Models
12-25-2015 02:28 PM
