Help with Cam Selection - Please
Folks,
I know this has been gone over a thousand times but Im not really able to understand too much of the technical speak. Can someone tell me in laymens terms what info I am looking for ?.
I have an 07 96ci Fatboy, Sert & pipes. and am wanting to do a cam upgrade.
Research has me believing the best choices would be Andrews 37h, 54h or Woods TW6.
My local indi mechanic leans towards S & S cams, which S & S cam can you reccomend for my setup ?.
Out of all the above does one stand out as the most simple bang for buck improvement for my bike.
Look forward to your help.
Rob.
RE: Help with Cam Selection - Please
ORIGINAL: skulznflames
Folks,
Rob.
Folks,
Rob.
Our 1st ride two days ago here in IN. His Duece walked away alot faster than before in a 6th gear roll on at 60mph against my 07 Heritage stage 1.
So take a look at the SE204 cams with 4 degree advance gear, this is the most popular cam at our dealership.
ORIGINAL: mp
What do you want to improve? Do you want more passing power out on the freeway, or stoplight to stoplight racing speed, or just a rumpity-rump idle? Some people will try to sell you what THEY like, rather than what YOU want.
S&S cams are all geared for top end power with their earlier opening exhaust valve. If your looking for WOT running get your self a S&S cam but if it is usable tq down low where you can use it the 37,TW6, or the 54,for the 103' there are more cam selections for a 103' build butthey will take a bit more cubic dollars to fit them into the build.
Folks,
Rob.
Folks,
Rob.
I have no experiance with the new Andrews grinds, but I hear they work well.
If your Indy is stuck on $&$ parts, find a new guy with an open mind!
skulz: Here is the cam comparator from Big Boyz website. Just select the cams you are considering and read Doc1's explanation of what the cam specs mean in terms of where the tq and hp come from in his earlier post today:
http://www.bigboyzcycles.com/tccams.htm
I have thepre-08 version of the HQ 500, HQ 0034, and find it is an excellent bolt in cam on my otherwise stock 88 w/Rinehart TD's and SE a/c '04 EG. It has an intake close 4 degrees earlier than the Woods TW6 or Andrews 26 which probably results in earlier torque as mentioned in Doc1's explanation referenced above.
As for your mechanic's preference for S&S cams, you might consider having him explain that to your satisfaction since HQ, Andrews, and Woods are all very reputable cam suppliers--it's your money after all that's going to buy the cams.
Last point--the HQ 500 is a cam that you could enjoyably use should you later decide on a 103 and a bump in compression from what you now have.
