idle help
idle help
I hope someone can help me. I just tried getting ready for the season and my bike is giving a buch of problem.
It worked fine before I garaged it. It started when I fired it but everytime I stand my bike straight up it would die. So i thought my float was stuck. took my carb apart and cleaned it and not its starts fine and runs when its leaning and when standing staright up, but now when I let the choke off the bike dies. When I give it gas it runs, but when I let off it dies.. Is it still because of the carb or is it beacuse I need to play with the throttle cable? I dont know what else to do.. its a s&s super g carb..
RE: idle help
Find and remove the pilot jet...clean it out and reinstall it....all will be good. (look in the manual for the location if you don't know) The jet itself has a VERY small hole to feed the fuel and it clogs very fast especially when the gas turns to varnish from sitting a long time.
RE: idle help
cleaned my jets. blew air nozzle threw it when i had it apart and still doing it.. is it because its 40 degrees outside? I put new plugs and it still fouled it. I have my idle mix screw turned at around 1 1/4. I have spark in my ignition, but when i turn the choke down the weaker the spark until it dies.. i dont know what else to do. i'm 22 so cash to take it to the shop is next to impossible.
After its dies, once in a while before it could start again, it would have a very loud pop, sounds like a gun shot.
RE: idle help
My first guess would have been that your gas started to varnish up your carb too. You say you cleaned it good, right? Floats are very sensitive. Are you sure you gotit back on undamaged and set at the right height? Will your bike stay running if you turn the choke/enricher off will keeping the idle up with the throttle? Do you have fresh gas in it?
RE: idle help
ORIGINAL: myglide
I really appreciate all your help guys.. I know these problems are simple to some people, but its just complicated for me.
