SE Street Performance slipons?
I'm looking at adding the above SE slipons (part # 80491-08, slashdown) to the new bike (along with the stg 1 a/c and maybe SERT) when it arrives and would like any opinions about them. I want a more aggressive sound than stock but not overly loud at cruise.
Should I bother with these? Anybody using them like or not like?
My dealer is 3 hours away so I can't spend a lot of time there listening to bikes so your opinions are appreciated.
RE: SE Street Performance slipons?
http://www.youtube.com/watch?v=lTfcN8dnS9w
If that don't work just do a search for "screamin eagle street performance" there is a couple of examples....J.B.
I have run those same mufflers on an '06 and now an '08 Ultra. They are just a bit louder than stock with a deeper tone. They perform well and dynoed out better by 5 ft-lbs of torque at 2800 RPMthan the older two piece street performance mufflers (64985-07) on my current 103" Stage II setup. The two piece mufflers had too much back pressure. I used a Radio Shack DB meter to measure the loudness of the one piece mufflers you are looking at and got a reading of 93 Db at 2000 RPM measure at about 3' and at 45 degrees up form the rear of the pipes. Unfortunately I didn't have the meter to measure what the stock mufflers put out for comparison.
I installed those slip on's with VH duals, fuel pak and hi-flow air. I rode the first time yesterday and was impressed with the performance and also the sound. When I hit it the sound was much louder than the stock mufflers but not too loud. It was just what I was looking for. The duals added to the sound.
I just got an '08 Streetglide with the SE Street Performance slip-ons, Stage I air cleaner, and SERT. The slip-ons sound really good, giving it a deep rumble. Louder than stock, but not as much as most aftermarkets. FXSTChewey put it pretty well about them coming alive under full throttle. I think you would like them.
