Fuel Pack on 07 Fatboy
I just changed my bike and got a 07 Fatboy I want to fit short shots stage 1 filter and Vance and Hines Fuel Pack.
I have the connectors to bypass the exhaust and air filter ecu plugs but notice that the ecu is fitted on the fender. The earlier Twin cams had a tray in the fender that was replaced with a deeper V&H tray and the fuel pack piggy backed to it. Has any one fitted one to their bike? I dont really want to cut a hole and fit a tray in the fender. Is there a extention loom ?
Paul
Paul
RE: Fuel Pack on 07 Fatboy
Paul,
If you go to the V&H web site, there is a link to the fuel pak site. I just putit on my 07 Deluxe, but you have a wide tire. I know that there was a different set up for the wide tire, but you different have to cut your fender. Let me know if you can't find it on their web site. I will go find the instructions in the garage and see if I can't scan and send them to you some how.
Chuck.
Chuck.
Mine was a tight fit. It took a few tries to get it all put in there, but it worked.
Have you got it up and running yet? I'm starting to second guess the whole fuel pak. I can't decide if I should go with PCIII or a SERT? Are you going to have the dealer do the Stage I on the your ECU? Because of the weather, I only have a hundred or so miles on it. I am not completly sold yet???
Chuck
Chuck
Take a look at this post and it will help you as to where and what to do with it all..
I found this when i had trouble fittinf everything in with my 07 FatBoy
https://www.hdforums.com/m_2235720/m...tm.htm#2987292
SlowPlay
04-08-2007 09:46 AM
