CAM FOR TC88B
CAM FOR TC88B
CAN ANYONE GIVE ME A POINT IN THE RIGHT DIRECTION FOR A CAM FOR MY RIDE,ITS A 2005 SOFTAIL CARBIE
S/E II SLIP ONS
S/E AIR FILTER
42 MM MIKUNI
S/E IGNITION AND COIL PAK
S/E PLUG WIRES
I WANT TO DO ONE MORE MOD THAT BEING THE CAM,I WANNA STAY AT 88" SO IM NOT LOOKING DOWN THE TRACK THIS WILL BE IT(BET YOUVE ALL HEARD THAT BEFORE)JUST A NICE CAM THAT WILL OPEN THINGS UP NICELY THROUGHOUT THE REV RANGE.
THANX FOR ALL YA ADVIVE!!!!!!! MICK
S/E II SLIP ONS
S/E AIR FILTER
42 MM MIKUNI
S/E PLUG WIRES
RE: CAM FOR TC88B
There are two in particular that I would look at, the HQ 0034, which will build you more torque down low and provide a flat torque curve throughout the rpm range. The other is the Woods TW6, very similar to he HQ in that it will build more torque lower in the rpm range where you do most of your riding. Both the 0034 and 6 will also work later on if you do make some changes to heads and compression. Another one to consider if your are sure you are only going to do cams is the Andrews 26, but it will not work as well if you do modifications later, it is basically a cam that likes stock compression. Good luck with your choice.
