Dynojet Numbers? How are these?
Horsepower went from 67.19 to 73.62. Torque went from 80.99 to 85.00. I thought the numbers improve more than this, or is this pretty good? I added a Vance and Hines Python exhaust, Arlen Ness Big Air Sucker, and PCIII.
Also, if I go to a true dual exhaust, I was told that my numbers would increase to probably close to 100 for both torque and horsepower. Is this true???
Thank you for your knowledge sharing.
RE: Dynojet Numbers? How are these?
If the same guy who told you that true duals would get you 100/100 as did your tune, find another tuner--he needs to put the crack pipe down, so to speak.
As for the numbers, they seem low for a stock 96 with higher flow a/c and lower restriction mufflers.
ORIGINAL: sweet street glide
If you do want to get into those kinds of numbers, look into a Head Quarters kit. They'll get you there!
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
No pipe change will get you to 100/100.
