evo exhaust on a twin cam?
I need someone who knows definitely to answer this:
Do Evo and Twin Cam engines have the same dimensions and locations of the exhaust ports? There is a set of exhaust I want to use on my 06 Springer. The description reads "fits 84 later FXST". That implies they were originally built to fit an Evo. But it also implies that they will fit Twin Cams too. I want to positive before I order. Thanks.
RE: evo exhaust on a twin cam?
Evo and Twincam engines have the same dimensions and location of exhaust ports, at least until 2006. If you search for exhaust systems, you'll see that for softails, all them fit since 84 until 06. But this is just in the complete exhaust systems, not slip-ons, as I believe that the rear brackets in evo and twincam are differents.
I think that if you purchase a complete exhaust system, it doesn't mind if it's been done for an evo motor.
Regards,
Javi
Regards,
Javi
