Alittle advice on somebody who found out the hard way about pistons!!
Most of you guys that do your own upgrades get good advice on parts and I do most of the time as well, so what the deal on pistons, I'm doing a 95" upgrade and wanted to go with SE pistons but I let my parts guy or indy talk me into a set of KeithBlack flatops, good pistons right, well maybe on the part about them making good power ect., but not as a user freindly piston, I could have just sliped the SE pistons in the jugs and slid them over the studs and slipped in the wrist pin and snaped in the c-clip and Bam, I'm done BUT NO, I have to put the pistons I have on the rods first, then install thespiral locksfrom hell in to hold the wrist pins in, then you have to put a ringland support on then install the rings, now if you have all the proper tools to do so it's still a pain in the azz, ya know what I mean, I destroyed one of thespiral lockstrying to put that sob in.
Anyways sorry about the long post just wanted to give you some advice that will make your build a whole lot easier than mine.
RE: Alittle advice on somebody who found out the hard about pistons!!
Those snap rings are a pain in the a ss, but I found a technique that worked for me and they went in pretty easy.
KB pistons are very good, probably overkill in a mild-95" upgrade..........but no harm done by using them.
Steve
Steve
RE: Alittle advice on somebody who found out the hard way about pistons!!
On the Spirolok wrist pin locks, I took a sharp pointed pick, like an ice pick, ground the point of it flat, and with it am able to walk the Spiroloks in by getting them started and going in a circle to guide them into the groove. Good idea to practice withone pistonon the bench with an extra lock first.
Geargrinder that is good to know. I though I was the only person who was challenged with these things. I'm sure they work well though.
I've got Spirolok and they almost made me cry. Broke out in a sweat on a cold day. I did something like you with a tiny flat screwdriver.
I think they would be useful in very high RPM situations, above 7-8000. Otherwise ,"C", clips are enough.
I have done 2 builds recently using the spiral locks and I liked them and once you figure out how they work you will realize they are superior to the C clips. I used SE on mine and I like the quality of the pistons just as well as the KB's I do like the Spiral locks better. I found the secret is to stretch them out about twice what the directions call for. It helps to have two sets of hands so one person can hold the piston/rod steady while the other person installs the spirals.
ORIGINAL: zoomie67
One of the engine builders I know says KB = Ka Boom
Now back to the pistons, I'm not just talking about the spiral locks, after you finally get them on then you have to install a ring land support on the piston and install the rings, now this can be a little tight because your doing this while there in the motor.
[quote]ORIGINAL: Tn.Heritage
this is where two sets of hands comes in handy. I also put some thin tape on the piston to keep from scratching it with the support ring. The actual rings go on easy but the support ring is pretty stiff and make sure the little nipple is facing the right direction because the support ring is a bitch to get off again.
ORIGINAL: zoomie67
