Good sounding injected bike?????
Old 02-18-2008 | 06:38 PM
07 standard's Avatar
07 standard
Default Good sounding injected bike?????
Does anybody have one with a nice rough idle to it?The tech i talked with at andrews tryed to tell me you can't do it.Horse pucky I have work on many injected cars and putaftermarket cams in them and sound great.Why would a v twin be any different?I just want to get rid of the stock boring idle......Someone has done this by now.Please let me know what you think....,John
Old 02-18-2008 | 06:46 PM
reded's Avatar
reded
Default RE: Good sounding injected bike?????
Let me know if you find out cause I thinkmy injected bikes sounds like $hit when sittin next to my bros carb'ed bike. His idles around 800rpm and mine sounds like its doing 2grand! Bleh!
Old 02-18-2008 | 07:13 PM
duke76's Avatar
duke76
if you have a thundermax with auto tune you can set your idle but I think it probably is not good for your bike with that slow of an idle, there is a reason they are set that high mostly because of the electronics on the bike it has to be charging good also to get good oil pressure, your buddies bike probably isnt getting the oil pressure it should be. HTH Todd
Old 02-18-2008 | 07:42 PM
global force's Avatar
global force
ORIGINAL: 07 standard
"nice rough idle?" lol. he's absolutely right. the sound you're referring to is characteristic of a carbed single cam motor with its idle speed set too low.
Old 02-18-2008 | 07:50 PM
heywood727's Avatar
heywood727
You'll never get it down to make it sound like an Evo. I believe it has to stay around 1000/1100 rpm or it will starve the heads of oil. Putting it lower is at your own risk.
Old 02-18-2008 | 08:37 PM
Old Gunny's Avatar
Old Gunny
All of the reasons for a about 1000 idle are right and also the ball and roller bearings in the case need to turn faster than 800 RPM to live well.
With a SERT you can set the idle to anything you want but mine wouldn't run good under 1040 RPM bacause the cam and springs need the energh there to keep turning good.
Old 02-18-2008 | 09:08 PM
07 standard
So you guys are telling me there is no such thing as a choppy idle with a cam change in an injected bike?
Old 02-18-2008 | 09:18 PM
reded's Avatar
reded
I don't know about you guys butI don't let mine sit around and idle all day. I can't recall it ever sitting and idling for more than maybe 30 seconds without me at least blipping the throttle some. I just don't like the fact that it blows the grass and dust up around me and sounds likea Datsunstuck on high idle after you start it. Even after it warms its still fairly fast for my taste.
Old 02-18-2008 | 09:23 PM
fatboydan's Avatar
fatboydan
I had the dealer set my idle down to 900 rpm on my 02 fuel injected fatboy
... THE ABSOLUTE LOWEST YOU CAN GO and maintain a good charge and oil pressure ...
I'm happy with it .... but a carbed bike set at 850 sounds way lots bunches better
Old 02-19-2008 | 12:01 AM
global force
sounds like you shoulda bought an older bike.
