Sponsored by: Jekill and Hyde
A couple questions...IRT SE street legal 103" kit
Old 02-14-2008, 09:57 PM
Big Twi$t's Avatar
Big Twi$t
Big Twi$t is offline
Default A couple questions...IRT SE street legal 103" kit
I have ALOT of questions, but I will start with just a couple right now. I probably wouldn't have to ask these if the search feature was working.
First, what makes one kit "street legal" over the other one? If I have aftermarket pipes, does it matter what kit I get anyway? Because it states that the Cali kit is only street legal if I use stock pipes.
I'm confused...
And, is there a better kit out there? (Yes, I read about 26 pages in this forum because the search feature is not working). If so, what?
Old 02-14-2008, 10:18 PM
wadejesu's Avatar
wadejesu
wadejesu is offline
Default RE: A couple questions...IRT SE street legal 103" kit
Street legal means meeting emission and noise regulations, There are all kinds of better kits out there, depends on how deep your pockets are, How much you want to do, Pull engine, Bore cases etc. I have built several bikes and engines in my home shop, Had to do it all over ?, Just leave in stock.
Old 02-14-2008, 10:35 PM
Big Twi$t's Avatar
Big Twi$t
ORIGINAL: wadejesu
Ok. So, I understand street legal = emissions & noise regs, but why 2 different kits? Is there a difference?
About the better kits...price would have to be in the ball park to the SE kits + or - a couple of hundred dollars.
One last thing...why leave it stock? LOL
Old 02-15-2008, 05:59 AM
TNBagger's Avatar
TNBagger
TNBagger is offline
If you look at the two 103" kits offered in the '08 parts and accessories catalog, you will see that the street legal kit (Stage II)has 255 cams and catalyst mufflers. Those two items are not in the Stage I kit. The 255 cams give better HP and torque results than staying with the stock 204 cams. I have the Stage II setup on my '08 Ultra with two piece street performance mufflers (64985-07). The bike is quiet and did OK on performance (86 HP and 96 ft-lbs TQ). Better flowing mufflers would up the dyno numbers but would also be louder which I can't tolerate anymore due to bad ears (tinnitus).
Old 02-15-2008, 12:41 PM
Big Twi$t's Avatar
Big Twi$t
ORIGINAL: TNBagger
Cool, thanks.
I failed to mentioned that I knew the street legal kit had the 255 cams. That being said, I guess I just blew offthe catalystmufflers because I have an aftermarket pipe. So, set those 2 differences aside...they are the same kits?
Another question. What's the difference between the '07 and '08kits?
Sorry guys for the newb type questions...this is how you learn and I've never been afraid to ask!
Old 02-15-2008, 03:27 PM
TNBagger's Avatar
TNBagger
TNBagger is offline
If you can find a dealer with last year's catalog, you can see if the the '07 vs. '08 part numbers match or not. BTW I tried a set of '07 CVO Ultra catalyst mufflers (like the ones in the Stage II street legal kit) on my '06 Ultra with a 95" build and they killed the performance - too much back pressure. Stay with your slip-on after-market mufflers and go with the 255 cams (worth as much as 5 HP and 5 #'s TQ over the stock 204's).Yes, the two kits are the same if you take the cat mufflers and the 255 cams away from the Stage II BB kit. My local dealer actually bored my cylinders out instead of replacing the jugs - he said that he had seen some of the kit cylinders that didn't mic out evenly all the way up and down the bore (not too good). I got a Stage II build for $1450.00 out the door including a download of map 106 for my SERT.
Old 02-15-2008, 03:47 PM
fj4069's Avatar
fj4069
fj4069 is offline
if you are not worried about a street legal kit sinse you got rid of the cats then ditch the se255 cams too. smog cams. tons of better cams to go with.
Old 02-15-2008, 04:48 PM
Big Twi$t's Avatar
Big Twi$t
ORIGINAL: TNBagger
Thanks for all the info!
I've come accross, while reading about the SE kits, they are not up to par. It seems the more I find out about them...the more I should go with something better...but what?
That seems like a great price for you stage II. I was quoted like $2100...that's with 12.5 hours of labor. F*ckin stealers![:@] I guess they thought I would jump right on that! LOL
Old 02-15-2008, 04:50 PM
Big Twi$t's Avatar
Big Twi$t
ORIGINAL: fj4069
I guess I'm not worried about it anymore. LOL
Suggestions on a good build (kit)?
Old 02-15-2008, 04:59 PM
donk_316's Avatar
donk_316
donk_316 is offline
Not 103 but a 107 https://www.hdforums.com/m_2876484/m...tm.htm#2876484
Quick Reply: A couple questions...IRT SE street legal 103" kit
