HELP... Idle cable problems
Had some free time, since the snow started again. I decided to re-jet the carb and change over to braided cables. All went good until I started to adjust the cables. The idle cable looks like it has too much play. If I adjust the cable to take up the slack, I'm at the end of the adjuster. If I follow the manual and tighten untilthe cable touches the spring it looks like I have a lot of slack in the cable. Another note if I adjust to take up the slack, I have no return on the throttle, (grip is too tight). Cables are routed good, under the tank, and everything looks like it's working. Maybe I'm just paranoid (too many days without riding), but I don't need the idle cable jumping off the return spring on the carb.
Thanks in advance for any info.
RE: HELP... Idle cable problems
melnik,
Are you adjusting the throttle cable for wide open first... before you try to take out the slack with the idle cable?
That thing about adjusting the idle cable until the spring touches never worked for me. Adjust the idle cable until the throttle just starts to stick with the handlebars turned full right, then back off the adjuster 3 or 4 flats.
Thanks for the thoughts,
I stopped back at the mecs shop today, and got a couple of ideas to try. I think I was adjusting the idle without keeping the throttle full turn. Another thought is that the inner cable may have been cut too long from the factory. I'll try readjusting again, before trying another cable. Gives me a chance to take the bike for test runs on these cold days.
ORIGINAL: melnikmd
