rattling noise-top front of engine
RE: rattling noise-top front of engine
Do you think outside or inside the engine?? Or maybe in Primary??
If inside maybe valve train. Stock engine or modified in some way? Are the pushrods stock or adjustable?? Rocker arm supports loose?? If modified with big springs clearance in rocker covers maybe?
Just trying to think of places that could becausing noises in engine.
While installing new bars I pulled the dash off and found one of the little stick on clips that hold the wiring had come off and was bouncing around in there. I haven't finished the bar install yet so I haven't been able to see if that helped or not. I doubt it but you never know.
redbug2
12-03-2013 07:02 PM
