cam choice
RE: cam choice
Haven't tried that particular grind, but I see no reason that it should be noisy. This grind has great specs (as do all Wood cams). I have used several Wood cams with similar specs, (TW6H & W6H) higher lift, a bit more duration, & it is in no way noisy.
The TW5G has to be a great cam- the .575 lift/ 234 duration with only 32 degrees of overlap should prove to be damn quick on the street. Torque, Torque, Torque---and that is where its at!!!!
