ss gear drive timing
01-13-2008, 05:47 PM
cams are timed together/inner cam gears are timed with cams/ do the outer drive gear time to anything? Only the small pinion has a time mark. Is that timed to crankshaft.
01-13-2008, 06:09 PM
RE: ss gear drive timing
I believe the big gear has a mark too! look real close!
01-13-2008, 11:23 PM
All SS 4 gears have timing marks. They must all match or you will have problems.
01-15-2008, 12:16 PM
you are correct, dont know how i missed the 1 time mark. I need to pull it off a rotate the crank a bit. No big deal! Thanks fo ryour input
wtsamatta
Engine Mechanical Topics
11
10-28-2016 05:33 AM
keithl3030
10-19-2014 06:09 AM
99dyna
05-10-2012 01:32 PM
Road King Kid
Exhaust System Topics
12-24-2009 10:55 AM
electra glide
11-23-2009 07:34 PM
