PC III map help
PC III map help
I have 2006 Fatboy with an SE a/c and SE 16 Gauge double barrel exhaust (I've been told it is the same as the Vance and Hines Double Barrel standard q series) and am looking for some fuel mapping help. Power Commander does not have a map specific to my exhaust and they recommend M805-208 (V&H BS staggered), but I know these pipes are louder than mine, and I assume if I use that map I will be running rich. Does anyone have a map for my set up that they will share? If not, any suggested modification I should make to the M805-208 map?
Thanks
Thanks
