EFI Idle Adjustment
Old 01-09-2006 | 09:42 PM
twstdharley's Avatar
twstdharley
Default EFI Idle Adjustment
Is there any way that I can adjust the idle speed on my 03 Road King EFI? Thank you for any input.
Bob
Old 01-09-2006 | 09:52 PM
John TN's Avatar
John TN
Big Kahuna HDF Member
Default RE: EFI Idle Adjustment
Not really, the IAC (Idle Air Control) sets the idle rpm, there is a way to manipulate it manually, but this would throw off the TPS (Throttle Position Sensor) readings which the engine relies on for it's values to tell the ECM the % throttle to 100% readings. Best take it to the shop for idle adjustments.
Old 01-09-2006 | 10:58 PM
MACK's Avatar
MACK
yeah, but you better be a damn good tech.It aint easy.
Old 01-10-2006 | 12:06 AM
twstdharley
Thank you very much, appreciate the advice. Bob
Old 01-10-2006 | 02:49 AM
bobcowan's Avatar
bobcowan
I could be wrong on the '03. But for the '06, the idle can be adjusted with a SERT. Or so I've been told.
Old 01-10-2006 | 03:44 AM
msocko3's Avatar
msocko3
ORIGINAL: bobcowan
Your correct, the SERT will allow you to change the idle. FWIW I don't know why someone would want to do that, I can't remember the magic number but there is a bottom line before you starve it for oil.
scotsport
09-21-2013 04:43 PM
bkessler28
05-18-2013 01:25 PM
mrodff
Engine Mechanical Topics
11-05-2012 05:46 PM
gtojets
EVO
02-28-2010 09:34 PM
irishviking
08-19-2008 04:48 PM
