stage 1 download enough for big radius install
Old 12-26-2007 | 11:04 AM
cherrypewt's Avatar
cherrypewt
Default stage 1 download enough for big radius install
just curious if my stage 1 download from HD is enough to go ahead and install a new set of big radius pipes,or will the computer need new re-mapping. also if the current download is ok,does anyone have anylean issues running the big radius??
[IMG]local://upfiles/29048/41E22C83EFD64A429935AB89C5C70510.jpg[/IMG]
Old 12-26-2007 | 12:17 PM
SEDELUXE's Avatar
SEDELUXE
Default RE: stage 1 download enough for big radius install
youll be fine. most down loads run lean. there are tons of guys out there running just down loads on their bikes.
Old 12-26-2007 | 12:41 PM
cherrypewt's Avatar
cherrypewt
i'm not sure if these free flowing exhausts(big radius) will actually make the engine run leaner...(if left alone) or will it run richer.....i'm a bit foggy when it comes to the lean or rich issue?
Old 12-26-2007 | 02:15 PM
cherrypewt's Avatar
cherrypewt
if the big radius are installed as is,will the bike run leaner or pretty much remain as is?
Old 12-27-2007 | 06:50 PM
SEDELUXE's Avatar
SEDELUXE
the stage 1 down load is for pipes and ac. When i first did the down load for my deluxe i had se shotgun exahust and se ac. ran ok probley lean . went to v&h bss and it was lean. went to the htcc set up 251 cam and bss down load real lean added a dfo richened things up ok. went to 98in re-worked heads r&r 615/585 cam sert 111/114. if you havent all ready done so get the sert of power commander.
i think youll be ok with the down load just lean .
jacob13217
08-22-2018 12:59 PM
toddlaroche
08-21-2009 07:49 AM
zuma
02-15-2008 11:50 AM
MovedtoSyracuse
08-28-2007 09:14 AM
mikesfxsti
08-12-2005 08:59 PM
