How can I tell if I have SE I download?
Bought 03 eglide used. Not sure if I have SE I download. I would say yes since I have SE slip ons & A/C. Going to put on true duals & ovals next week. I found numbers on unit behind battery that are 8566 305.Delphi EFI. Going to run Fuel Pak. I am not planning on doing anything to the motor.
Thank You for any info regarding this.
RE: How can I tell if I have SE I download?
I would gather that if it was done properly when changing out the A/C that it does. It could have also had the SERT and was just not included with the bike. In any event, if you are changing out the pipes and running the Fuel Pak, just put in the map as if it had the Stage 1 download and see how it runs.
If I remember correctly when I ran a Fuelpak they had two map variations for each map, one for a bike that already had a Stage 1 download and one for a bike that didn't. You should be able to tell if it didn't if you load the map for a bike that has a Stage 1 download (which I would do if I were you) and you check the spark plugs, listen for popping, etc.
Ultra_RB
The Dyno Room
07-15-2018 03:28 AM
