suggestions
suggestions
bike is an 03 FATBOY started out 88 in now cracked cases and dropped in 103 flywheels also has 258SE cams SE mappable ignition V&H pro-pipe HS with torque baffle 45 mm SE mikuni last dyno run was 100 hp 107.8 tq. still not satisfied called bob wood he said i could do much better recommended tw6h cam +4 degree cam gear change from 3"15 to 3"37 gearing. while i do that i,m gonna port polish SE cvo heads Tp engineering roller rockers billet rocker support fueling oil pump dekron support plate. change torque baffle out for competition baffle i have. #1 any ideas oninmprovement over old dyno numbers and am i leaving any thing out??? oh yeah dropping a 6 speed in it to make it highway navigable.....i know about keeping "B"engine under 6200 i just want to get there QUICK!!!
RE: suggestions
I enjoy reading enthusiastic posts by guys doing engine work.
You don't mention which 103" crank you are using and that'scritically important.
You also don't mention what porting is going to be done, what your compressionwill be,etc.
As for the cam plate and oil pump, the SE plate/oil pump gets excellent reviews.
Sounds like you are willing to spend a lot of money for well-known parts without a clear idea of how they will all work together. Unless you are an experienced builder or have knowledge of what you are putting together from a proven source, I'd suggest youhang on toyour money until you do. Really, with the information you provided it's impossible to say much else.
RE: suggestions
This is good advise. I never like to see someone pick a cam and then pick a porting shop because they usually wind up dissapointed, frustrated, and brokein the end. I have several proven combinations that I use and once I install one of these for someone, here comes their buddies. You have several parts listed that I would not choose.
