Boot marks on exhaust pipes...
RE: Boot marks on exhaust pipes...
Brillo pad worked best for me . I then use the chrome polish . I have a tube
of Blue be gone , but I must not be using it right . lots of elbow grease .
I do like Mothers ok ,but about the same result . Do you like it ? Maybe the next time i'll use my glasses .
lostinal
lostinal
Very fine steel wool (finest you can get ahold of) and chrome cleaner/polish. Don't get into a rush, patience is the name of the game. Work on the boot marks slowly and avoid the urge to use too much elbow greese. I have used this combination (steel wool and chrome cleaner/polish) many times and have always had great results.
ORIGINAL: igniter
If you go to a home improvement center, Home Depot, etc. You can find 0000 steel wool. This is as fine as I've seen. It works great. I've used it on bluing for rifles, etc. and on chrome. Just remember finesse.[sm=signs003.gif]
Ryan
ORIGINAL: Vegas FLSTN
I've had good luck just dipping a rag into some gas
Good luck!!!
ORIGINAL: jcc/tx
Something similar, but I find handier, is engine starter fluid. I keep an spray can of it on my work bench. It is not hard on paint either and is an excellent general purpose cleaner/solvent.
Good luck!!!
Good luck!!!
Ryan
