2004 1200 cylinders HELP PLEASE
Old 12-11-2007 | 06:23 PM
xrayss's Avatar
xrayss
Default 2004 1200 cylinders HELP PLEASE
I purchased a 2004 1200 sporty wreck. I need to replacethejugs and am looking for the most cost effective way. I was looking at 883-1200 kits but can not confirm if the conversion cylinders are the same as stock 1200. I was told by one person that they were designed for 883 heads and are not the same. Any information would be greatly appreciated. Also are 04-07 the same?
Old 12-12-2007 | 01:05 PM
Kingofcubes's Avatar
Kingofcubes
Default RE: 2004 1200 cylinders HELP PLEASE
883 cylinders bored to 1200will work well for you.
Old 12-12-2007 | 01:14 PM
extech's Avatar
extech
If you do a conversion the cylinders are the same,you just have to use the correct pistons(pn22698-01) that will be compatible with the 883 heads
Old 12-14-2007 | 03:41 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If your looking for more than just the conversion piston (concave), a set offlatops, N-8's, and a Black Diamond valve conversion to the heads, and it'll tune out at around 80/80 or more.
That, my friend, is a mighty quick little bike.
Your buds on the bigger bikes won't like that.
Old 12-15-2007 | 09:54 AM
Kingofcubes
The last one we did got 93 hp with 87 torque and revved so quick it beat a bike with more hp by a heap in a roll on run. The heads were stock 883 modified with bigger intakes and cut down exhausts.
jamespedro28
Engine Mechanical Topics
36
01-23-2024 04:16 PM
divco13
11-09-2019 09:27 PM
kauffman_c
05-03-2011 11:27 AM
keithnhsporty
03-25-2011 09:12 PM
olesalt
10-31-2006 11:19 AM
