Replacing the enricher cable
RE: Replacing the enricher cable
ORIGINAL: BG Weasel
I replaced it on a 1990 fxr (evo). And yes, I pulled the carb to do it. But neither pulling the carb nor replacing the cable was hard.
I don;t know if this'll help you at all, but I have my carb off my bike right now, so I took some close-up shots of the enrichener and where/how it attaches to the carb.
You can check em out HERE
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Cheers!
ORIGINAL: Clammy
Cheers!
Cheers!
Do you have any idea how the cable attaches inside?
ORIGINAL: Hdbiker1450
Thanks, Clammy! Yep, those helped, since I haven't taken it off yet. Too friggin cold. We have a carport with an attached 10X25 shed. That's where I keep her. Hoping it'll warm up enough to work on her this weekend.
ORIGINAL: Clammy
Cheers!
Cheers!
Cheers!
The carb needs to come off. The threads are fine and the plastic is soft real easy to cross-thread. After you get it off you will see a brass enrichener on the end. It is held in place by the spring. Slide the spring back and take the enrichener off the ball. You will need the spring and enrichener for thew new cable, reverse the process to assemble. Be sure you have the cable all the way in or your bike will run rich.
ORIGINAL: miacycles
