Tool Rental
11-13-2007, 02:03 PM
Tool Rental
Changing to gear drive cams in a 95 build. Need inner tools to pull bearings and install new. Anybody out there rent this.
Thank you in advance.
11-13-2007, 02:15 PM
RE: Tool Rental
autozone has a blind bearing puller set that uses a slide hammer to remove the inner bearings. they come right out easily. the outer bearings will come out using a brass hammer on the ends of the cams. going back to gether works easier if you freeze the cams and bearings and heat the support plate to about 200 degrees in an oven.
11-13-2007, 02:32 PM
RE: Tool Rental
Thanks for the info
11-13-2007, 09:36 PM
RE: Tool Rental
Go to "Harley tech talk" forum and ask question there. There is a guy that rents the correct tools for the job all the time and very ligite.
04-01-2018 07:52 AM
Fixedgame
Exhaust System Topics
02-28-2013 06:34 PM
DirtyD1833
12-31-2012 12:40 PM
CT-Bagger
11-01-2010 03:22 AM
Varooom
03-20-2009 01:26 PM
bassani ,
davidson ,
harley ,
pro ,
rent ,
rental ,
rentals ,
rents ,
tool ,
tools ,
turnouts
