Which exhaust gaskets to use ??
Just removed my D&D Fatcat exhaust from my 07 SG to replace a broken heat shield clamp. Used stock exhaust gaskets when i first installed the pipe, but i didn't seem to be able to get the nuts on the rear cylinder tightened down as far as i think they should have been. Any one used the screaming eagle donut's with any luck ??
RE: Which exhaust gaskets to use ??
The SE look more like a standard gasket and mating surface deeper in exhaust manafold while the standard is tapered and can somethimes be a pain to get inexhaust port. However once the gaskets are in properly starting nuts should be no problem and torque precedure is the same. In the manual.
