07 & 08 Pipes on earlier years ?
Old 11-06-2007 | 10:59 PM
Rastus's Avatar
Rastus
Default 07 & 08 Pipes on earlier years ?
Have an 03 Roadglide and want to install either a Tmax or Twin Tec. I want to change out pipes as well. Can I use the pipes designed for 07-08 with 02 sensor bungs install already on earlier years without fitment issues ?
Old 11-07-2007 | 07:44 AM
akpauly's Avatar
akpauly
6th Gear
Default RE: 07 & 08 Pipes on earlier years ?
Yes, I'd be interested in the answer to this as I've considered it myself!
Pauly.
Old 11-07-2007 | 09:38 AM
extech's Avatar
extech
I recently talked to someone at Tmax they said Rush was going to come out with a set of duals for the early models with the bungsalready installed.
Old 11-07-2007 | 06:06 PM
Rastus's Avatar
Rastus
Anybody know ?
Old 11-07-2007 | 06:26 PM
NCCopBikeRider's Avatar
NCCopBikeRider
06 electra glide with 07 pipes.
Bolt on, no issues.
Works well instad of welding bungs on old pipes
Old 11-07-2007 | 06:48 PM
speedglide's Avatar
speedglide
The only difference I have heard so far is the mounting bracket for the rear pipe bolted to the top of the tranny. It's a bit different on the 07's up..
Any problem with that particular bracket NCCopBikeRider???
Old 11-07-2007 | 07:16 PM
Rastus's Avatar
Rastus
ORIGINAL: speedglide
I plan on running a 2-1 so I'm not sure if the bracket your referring to would apply ? I'm wondering if the bracket you're referring to is because of the 6spd trans ? None the less I'd be curious to hear from NCCopBikeRider if he is running duals on the bracket situation.
Old 11-11-2007 | 10:33 PM
Rastus's Avatar
Rastus
Anybody else ??????????
Old 11-15-2007 | 08:14 AM
gunnert's Avatar
gunnert
The 07/08 pipes will fit, but they are made to go out around the 6 speed trans. Mounted on an older bike the pipe will stick out further and there will be a gap between pipe and trans. The pipes are easy enough to burn your leg on, I'd be careful about extending them out even further.
Old 11-17-2007 | 06:57 PM
NCCopBikeRider
No bracket or leg burns
Quick Reply: 07 & 08 Pipes on earlier years ?
