EVO S/E Heads
Old 11-01-2007 | 12:16 PM
Deus Ex Machina's Avatar
Deus Ex Machina
Default EVO S/E Heads
Anyone using them and if so did you slap them on as is or did you have any work done to them? Which Rockers, Cam ect ... Provide details if you can, TIA.
Lee
Old 11-01-2007 | 01:27 PM
HDWRENCH's Avatar
HDWRENCH
Default RE: EVO S/E Heads
The se evo heads are not bad out of the box. I would at least cc the heads to ensure that the chamber volume is the same from front to rear. In that process remove the pc coating in the chamber as that is going to burn off any ways and will effect the cc reading. Mild clean up in the ports is always nice as well. Check the valve seals to make sure they are on correctly and tight.
grieker
10-23-2014 09:53 AM
lofathd
Evo Era Parts
09-18-2012 11:55 AM
chivo2you
11-13-2008 06:05 AM
grattray
05-06-2007 04:15 AM
