07 FLHT Oil Temp Gauge
Old 10-24-2007 | 11:07 AM
BubZ's Avatar
BubZ
Stage III
Default 07 FLHT Oil Temp Gauge
Can someone tell me what the additional adapter for an 07 FLHT oil temp gauge kit is, and where it mounts. I'm thinking about putting the temp sensor in the extra plug on my oil pan but I noticed it looks like the sensor would thread into either one of the holes on top of the oil filter bracket as well.
If it makes more sense to do it with the HD adapter I will, but if they are trying to sell me a $2 pipe adapter for $47 then of course I'm nt going that route.
Any insight would be greatly appreciated.
BubZ
Old 10-24-2007 | 11:16 AM
07SG's Avatar
07SG
Default RE: 07 FLHT Oil Temp Gauge
If I understand correctly the kit that you refer to contains a T-fitting to splice into the rubber oil cooler line.
I too thought about what you are considering at the oil filter, but decided against and just installed in the pan. I figured the sensor would stick out and look like crap.
Old 10-24-2007 | 08:20 PM
jlelliott's Avatar
jlelliott
Don't waste your time with the adapter that puts the temp probe in the cooler bracket. I don't know of anybody that has successfully done that. It just doesn't work. After replacing probes and guages my dealer finally gave up and put the probe in the oil pan. The adapter kit is a waste of $50. HD won't acknowledge the problem with the design of the adapter kitbut is more than willing tokeep replacing probes and/or guages until you get tired of the hassle and put the probe in the oil pan.
Old 10-25-2007 | 12:57 PM
NCCopBikeRider's Avatar
NCCopBikeRider
Get a 3/8" x 1/8" brass "bushing" at any of the big box hardware stores.
Intsall it in the "spare" opening in the oil pan.
Simple, easy fix.
Old 10-27-2007 | 03:13 PM
BubZ's Avatar
BubZ
Stage III
I would have to agree that the oil pan is the best choice. I appreciate the info. Now can someone help with the wiring? The instructions are incredibly vague. Does the power and ground need to picked up in the fuse box behind the side cover or can it picked up behing the fairing?
Heck, I'm not even sure the fuse box behind the side cover is what they are referring too. They really go out of thier way to get you to bring to the dealer but I'm ot going to do that. I worked my way through college as an instrument and electronics tech so I know how to doelectrical work. I have the power going to the acc switch that is not going to be used...what do you guys think?
BubZ
Old 10-27-2007 | 08:06 PM
Harleypingman's Avatar
Harleypingman
Bub: I installed the sender in the pan and used the power and ground inside the fairing.
BornTexan
03-02-2014 07:13 PM
nccinstaller
06-27-2010 11:29 PM
OnTheFence
Oil Archive (no new posts)
16
03-09-2008 03:28 PM
FKR FLHX
09-07-2007 07:13 AM
lenny
General Topics/Tech Tips
12-10-2006 10:13 AM
Quick Reply: 07 FLHT Oil Temp Gauge
