cam change
Old 10-13-2007 | 09:15 PM
hdfatboy54's Avatar
hdfatboy54
Default cam change
can any of you guys tell me which would give me the best stock performance on the twin cam 88b, I have 35,000 miles on it and was considering going with andrews cams and gear driven. Would this be an improvement over the chain. I know noise is a factor, but the noise wont bother me as long as it will be a power improvement.
Thanks Jim
Old 10-13-2007 | 09:40 PM
mentor70's Avatar
mentor70
Default RE: cam change
I think gears are best!
that said there are many choices for for bolt in cams, Head-Quarters 0034, Woods TW6, Crane 310, S&S 510 and Andrews 37s are the most popular. Any of the above should get you kickin some ***!
Im suprised you waited sooo long for cams!
Old 10-13-2007 | 09:44 PM
04RoadKing's Avatar
04RoadKing
ORIGINAL: mentor70
Yeap everthing he said.......................
Old 10-14-2007 | 07:52 AM
hdfatboy54's Avatar
hdfatboy54
thanks guys, you just made my mind up for me. any advise on the best buys.
Old 10-14-2007 | 10:43 AM
mentor70's Avatar
mentor70
well, the Head-Quarters and Woods, bolt ins are giving the best #s and broadest power right now.
Old 10-14-2007 | 10:56 AM
xxxflhrci's Avatar
xxxflhrci
I like my Andrews 26G's.
Old 10-14-2007 | 08:16 PM
JLOCKHART29's Avatar
JLOCKHART29
Don't sweat the noise. If your run out is in spec and you set them up right they are quite as chains.
Old 10-14-2007 | 08:21 PM
clutchglass's Avatar
clutchglass
Andrews has my vote & they are American made too.
-clutch-
Old 10-14-2007 | 09:24 PM
mentor70's Avatar
mentor70
ORIGINAL: clutchglass
-clutch-
which ones are made elsewhere?
I dont know of any made outside the US.
Old 11-08-2007 | 07:43 PM
2005UltraNC's Avatar
2005UltraNC
I put in the 26G's - can't hear any whine at all. But, advice, BEFORE buying the cams, check the crank shaft runout. If too much out of spec, you'll need to stick with chains. There's also a kit to upgrade to the 2007 chain setup - which is supposed to be much better than 06 and prior chain drives.
Quick Reply: cam change
