SE 204 Cams
SE 204 Cams
OK, I trust the opinion of a lot of people on here so here's my question. I want a little more low end power. Without going to a 95" upgrade, can I get away with just putting in SE 204 cams and SE ignition and wait until I have the money for the actual 95" upgrade? Will this give me what I want for now?
RE: SE 204 Cams
Yep, the 204's will work with your stock cr and give you a little boost. But the full potential will not come to pass until you do some headwork and a bore upgrade.
Dont waste your money on the SE ignition. If your going to do an ignition upgrade do either the S&S IST(best period), or the DTT TC88 module. SE igntions are a waste. Many of them are canned with no means for adjustments. You want a flexible ignition that can grow with you.
RE: SE 204 Cams
ORIGINAL: CptKaos
There is a Race Tuner for carb bike ignition modules, allows you all the adjustments
Larry
Larry
justmealwatts
04-24-2009 11:12 AM
67xlch
10-05-2007 11:59 AM
