Replacing V&H Ovals with Rinehart True Duals
I have a 2005 FLHT with Stage-1(Harley remap),95 inch Big Bore Kit (SE 203 cams)and Vance and Hines Oval Slip-ons. I am considering going to the Rinehart True Duals.
Would I need a remap or can I switch them out and ride for a while until I can afford a Power Commander and Dyno time?
Also, any opinions on if I'll see any performance gains?
Thanks
Thanks
RE: Replacing V&H Ovals with Rinehart True Duals
A buddy of mine has a set laying around and said I could try them out. His old lady made him take them off because of the noise. My bike runs greatwith the V&H ovals but I'd still like to see howshe performswith the Rineharts. Every little bit helps!Eliminatingthe crossover would make the bike look better but I am concerned about the"back-pressure" issues even though I must admit I don't understand it all.
Thanks,
Dave
Thanks,
Dave
For the cost of a couple of exhaust gaskets and some clamps, give it a shot. The difference in exhaust air flow with the duals is probably not enough to require remapping the ECMto correct a/f. Lots of folks prefer the "look" of Rinehart TD's and and their sound, myself included.
Performance-wise, you might lose a little torque in lower rpms, but see some gains in hp above 3000 rpm. Unless you have a very sensitive "butt dyno," you will probably notice the look and sound far more than any performance change.
Kicks
04-04-2014 05:53 PM
09BlueRoadKing
08-07-2013 09:44 AM
