injected 04 hard to start when cold
My girlfriend just got an injected 04 Wide Glide, and when the engine is cold, it takes a long time to start. It has 13,400 miles, stage 1, open K&N filter, SE exhaust--no baflfles. You press the start button, and the engine turns over plenty fast, but just keeps turning over. We have to try 3 or 4 times for about 10-15 seconds each until it finally starts. then it runs pretty rough for a few minutes, then runs fine.
It does pop and crackle, even when warmed up, if you partially let off the throttle from a cruise. It doesn't do that if you let off all the way.
So where should I start with the starting problem?
UPDATE: injected 04 hard to start when cold
well, I think I figured it out. I can wrap a towel around the air cleaner, and it starts IMMEDIATELY when you hit the button. So I figure it doesn't have the stage 1 download, and is getting too much air flow.
Well, I'm right...it doesn't have the stage 1, but DOES have the SERT!!!! Problem is, I bet the original owner kept the box, and there's no chance of finding it. Bummer.
RE: UPDATE: injected 04 hard to start when cold
Try shoving the baffels back in and see what the start situation does...That's strange, a throttle body that needs choked...something not right there. A stock bike will start with no breather attached at all, but that same bike will not run worth a darn without proper back pressure on the exhaust. Running an engine without the correct back pressure does bad things to valves, gaskets and piston tops.
Andy Malham
09-05-2018 07:03 AM
Cruzn34
03-25-2013 01:55 PM
