07 Softail Standard Mufflers - Mods?
Hi All,[/align]The sound of my stock mufflers is getting me down. [/align]I've found anotherset of standard mufflers and have heard that I can get a better sound (and potentially better performance) by modifying them.... Is that true? What can be done to them to make the exhaust sound deeper?[/align]Thanks for any tips[/align]Pauly[/align][/align][/align]
RE: 07 Softail Standard Mufflers - Mods?
Hi All,[/align]The sound of my stock mufflers is getting me down. [/align]I've found anotherset of standard mufflers and have heard that I can get a better sound (and potentially better performance) by modifying them.... Is that true? What can be done to them to make the exhaust sound deeper?[/align]Thanks for any tips[/align]Pauly_2[/align][/align][/align]
Pauly,I was in the same situation you now find yourself in. I had an extra set of mufflers that I wanted to modify to get a better sound.There is a thin piece of metal preventing the mufflers from being flow through about eight inches in from the rear of the pipe. All I did was get a long one inch drill bit and drilled a hole in it. It helped a little but it wasn't what I was looking for in sound and volume. I ended up buying a set of rush slip ons and couldn't be happier.
If you do a search you should be able to find many threads on the same subject. Good luck with the mods.
