Dyno with V&H Quiet Baffles
I'm scheduled for a dyno tune on Saturday. I'm running V&H Big Shot Longs with quiet baffles on an '06 FLSTCI. The quiet baffles seem to be pretty much closed at the rear, compared to the regular baffles, and the tuner said he thinks he'll have to drill a small hole in the baffles to get the probe where it needs to be.
Has anyone else had this done, and has the drilled hole caused the sound/tone/volume to change?
RE: Dyno with V&H Quiet Baffles
I have the big shot staggards and installed the quiet baffles prior to getting the dyno done. The tuner had to drill a hole in one of my baffles to get the sensor to the front of the header.
He said I wouldnt notice a change of any sort. Personally I did. It sounded tinny like with the regular baffles. So I bought a new one to replace it.
The quiet baffles did seem to help the torque though. I got 84 lbs and 80 hp. I was happy. The tuner though the open element filter and back pressure helped.
If you have any more questions let me know.
The quiet baffles don't really make them much quieter--just 2 to 3 decibels, according to V&H, though that's really more than it might seem. However, they lower the tone significantly, getting rid of the raspiness that many V&H pipes put out, and giving the pipes more "rumble." When you compare the baffles, they look completely different.
I don't know how they affect power compared with the standard baffles, as I've never run the standard baffles. But on Saturday I will know how they compare, power-wise, with Rush pipes with 2" baffles, and I'll post the results here in a new thread. All other variables will be the same (same tuner, etc.) with the exception that I've since switched from a Screaming Eagle air filter to a K&N filter.
Dale M Ludwig
Exhaust System Topics
02-26-2012 05:19 PM
Larryc5079
06-15-2007 09:05 AM
