ENGINE BUILD ADVICE
RE: ENGINE BUILD ADVICE
ORIGINAL: BM83
I have a 2007 road glide that I'm building as a 103". I am asking for some advice on the build from some folks with experience in this area or from some who have done something similar and can give real world results. I ride to work every day about 100 miles round trip and do some two up riding with luggage on occasion. I want to get better performance but do not want to have detonation issues or a significant loss of torque in the low end. Wondering what commpression, cam profiles, and heads to go with. Right now I have the SE air cleaner and rinehart true duals with SERT and oil cooler. I have the big bore cylinders but have held off on the heads,cams, and pistons until I can get a good idea on which way to go.
Thanks in advance
Jason
Thanks in advance
Jason
ORIGINAL: PhilM
Contact Wilson Cadle..... He does a ton of HQ builds in your area and then see Kevin Baxter for a tune.
You are VERY lucky to have Kevin so close!!!! He is one of the best SERT tuners out there!
I will PM you an email address to contact Wilson....
Wilson is a great guy he hooked me up with my ignition down load. He really knows what he's doing, Kevin is great too.
I agree HQ does great work. But for what you described, I'd suggest a mild porting of the heads, S&S 585 cams, compression around 10:1. Properly tuned with your pipes this setup will run quietly, be easy on the valve train, and make over 100 HP and over 110 lbft Tq.
[IMG]local://upfiles/18192/E24794DF6CF74AD3A8D6401DFB66D314.jpg[/IMG]
ORIGINAL: gunnert
and the HQ setups will deliver 15 to 20 more HP. and torque.
