Does anybody know
RE: Does anybody know
Sorry Softy, but a dyno has absolutely no way of determining how many cubic inches there are in a given engine. There are only two ways that I know of to determine C.I. (1) Teardown and measure, or (2) Pump the cylinder with a pre-determined amount of fluid, (basedon known values for cylinder size and stroke). Thats basically it! Option #2 does not require engine teardown, just some math and some type of measuing device to hold a specified amount of fluid.
ORIGINAL: Bowtieman31
ORIGINAL: Softy
I understand your point,but a 95 " willshow a significant increase in HP and Tourqe,hardly possible to duplicate with a stock 88". The dyno measures hp and torque.I don't know much,but I know what a dyno does...
You may know what a Dyno does but you still won't be able to tell if it's a 88" or a 95".Just a plain 95" Big boreis not that significant of an increase in TQ or HP.When my Road King was still an 88" I put in a set of S&S 510G cams and I it would walk away from just a plain 95" with stock cams. Heck My 88" would run neck & neck with the 2003 SE 103" Road Kings all day long. Now that I did the 95" with High compression and head work my Road King will eat up a SE 110"
ORIGINAL: pauletich
It needs to be torn down to be sure. The HP and TQ will let you know if its been beefed up, but I have seen some 88ci that are in the 100's on both HP and TQ.
When I bought my bike it was used... I wanted to have an extra set of keys made... My parts guy pulled up the VIN... he told me who the previous owner was, he also told me no additional work had been done to it "by a dealer"
You may be able to check if your bike has the upgrade this way if it was dealer installed. I don't know this for certain, but my parts guy showed me on the computer screen all the pertinent info regarding my bike... Could work for you if there is a 95" and it was dealer installed..
